G
graemesavage
Hi
I want to change my kitchen down-lights to LED's, I have 12 down-lights, 6 on one dimmer switch and 6 on another dimmer , I have tried dimmable LED's in 6 of the lights but they are just flickering, do I need to change the dimmer switches and the transformers to make these work.
Transformer are Aurora 10-60W/VA (see picture)
Any help would be greatly appreciated
you'll probably need to replace the dimmers, and the transformers for LED drivers.
Dimming LED lights is much more hit-or-miss than filament lamps. Even with a LED-friendly dimmer they can have different modes of operation to try and get good behaviour. You might want to look at these, or maybe contact them for advice:
I'd recommend the Varilight vPro used alongside the Varilight lighting transformers. Changed 12v MR16 lamp systems over to that combination on multiple occassions and had no problems apart from 1 dodgy dimmer module.
cheers , thanks for that ,I've been looking at Varlight
