The OP concerns a socket not working. A short circuit refers to a fault of negligible impedance between live conductors or live conductors and earth. If there was such a fault to an earth wire of course a current would flow, but that current would normally be of sufficient magnitude to operate the protective device, disconnecting the supply, which would be apparent due to a tripped device. That is how a circuit is designed. Some appliances operate with a normal tiny leakage of current to earth, however this would not account for an inoperative socket so is a moot point with regards to the issue that needs to be resolved. From your post which has been deleted along with my reply it was apparent that you are confusing voltage and current, and that your advice on testing for those was seriously flawed and potentially dangerous. I hope the above helps, but please post any questions and I will try and answer without appearing to be 'mocking'
