I'm not saying I would do this because I wouldn't install like this, but I am going to play devils advocate.
Which regulations does such an arrangement breach?
And how would two ring final circuits installed in accordance with the regulations connected to the same 32A MCB be dangerous?
As I say I wouldn't do it, except as a temporary measure to restore supply, so I'm just curious about the thought process behind the statements.
You are correct. It would, nt be dangerous as the mcb will simply trip when overloaded. However, would it be good practice? No. Would it likely cause inconvenience for the homeowner? Almost certainly at some point
[automerge]1596397821[/automerge]
What's a "mini ring"?
Here's to "Ring circuits" one of the dinaosaurs of the electrical industry. Don't wish to offend anyone but having operated in one of possibly only 2 countries that actually use this wiring method I would hope that threads like this speed up its demise and finally put it out of its misery. It never deserved centre stage and was never going to be able to upstage its bigger brother on the world stage.. the Radial circuit. That said I have used it occasionally. It can in certain circumstances be a "get out of jail card".
Ohh Edmond you are going to get some flack for that comment, although I agree.
You can save some effort by just going through this thread:
That is a good thread actually. I appreciate the arguments for and against. I should say that I like you served my time in an environment where rings circuits were common. But they have fallen out of favour for the simple reason we find radials more advantageous. Now to those who have a preference for the ring circuit, all the best to them. Our regs still allow ring circuits but there are increasing restrictions on their use. I have not seen a ring circuit installed on a new build in the last 30 years. Its unspoken, but overhere there is a feeling that the clock is ticking on them.However as I mentioned they have a role to be play. On an occasion recently (installation with poor electrical design) we combined 2 radials to make a ring and it solved a major headache. But it's in that role I have always seen the ring, as a support, rathar than the main act
Advantageous in what way?
Now to those who have a preference for the ring circuit, all the best to them. Our regs still allow ring circuits but there are increasing restrictions on their use. I have not seen a ring circuit installed on a new build in the last 30 years. Its unspoken, but over here there is a feeling that the clock is ticking on them.However as I mentioned they have a role to be play. On an occasion recently (installation with poor electrical design) we combined 2 radials to make a ring and it solved a major headache. But it's in that role I have always seen the ring, as a support, rathar than the main act
Is this part of a move to closer alignment with EU wiring practice (similar to your T&E going for equal-size CPCs)?
Or any other specific reason(s) for the preference?
Ok now you've got my dander up! Ring circuits will probably disappear eventually. But the reason is not some technical reason it is because of the dumbing down of the population in general. As regards the origins of the ring circuit it was maybe ahead of it's time ecologically as it was to save copper, ergo the natural environment. As you know I am an advocate of the ring circuit as per the other thread you referred to. Perhaps you are an agent provocateur insidiously dripping non reasons for getting rid of the ring circuit? It seems you don't like them with a vengeance. Which is a bit strange not to be dispassionate about a bit of wire and solely concentrate on the science and reasoning of each circuit type. Both have their merits and application, you just jolly well leave our ring circuits alone chappy.;)
In line with EU practice, Dual pole MCB's and radial circuits will halve the time taken for inspections and fault finding.
Dives for cover. :innocent: :eek:
Does EU practice mandate that radial circuits run simply from point to point? If any branches are permitted then surely inspection and fault finding becomes less straightforward.
I ask this because I remember reading about some European countries where it was common to find radial circuits that branched off in many directions - sort of like a tree.
