Couldn't see that until the photo was viewed on a separate page! Never seen a crabtree switch like that before.That's a Crabtree switch. Name is moulded in plate, bottom left.
RPP sockets had double screw terminals, they were colour coded too.Quite like the double common terminal, saves the 2 conductors in one. First time have seen one.
Thanks, that is really clearThey are push-wire terminals which only accept one wire each, so the common is doubled to allow a loop-through. Put both red wires into the one common terminal in the new switch.
The most logical expalanation of what we see is that the switch cable from the light(s) is the 3C+E, carrying PL, SL and N. The T+E is either the feed, or it is taking PL and N on to another point.
