Multiple kitchen appliance failures
C
Cpflatman
I recently purchased a new property and in the three months we've lived here three kitchen appliances have had/ developed issues:
  • Beko induction hob would not heat, appliance repair company said the main power control board was faulty and needed replacing;
  • Half of 4 slice toaster (note: plugged in via surge protected lead) stopped working
  • Hotpoint oven worked for 2 months, then lost power completely during cooking and will no longer switch on at all.
Is this likely to be a coincidence or is there an electrical explanation for this?
I have reason to believe the kitchen electrics were not done by a professional, I have been made aware of several building regs contraventions since moving in.
I would like to know so i can get a quotation from an electrician to fix this.
Thank you
Is this a new built property?
If not, was any electrical report done prior to purchase?
No issues with lights flickering.
No survey I'm afraid.
I should have mentioned that the appliances were all quite new, hence my suspicion.
Surge that has then slowly caused the appliance failure? Poor quality appliances - Beko? Difficult to say without investigating.
Thanks. Was just wondering about a dodgy incoming neutral.
Poor Beko hob was my first thought, but then the oven (seemingly good quality) and toaster (which ran fine in previous houses for 2+ years) appear to have gone in quick succession.
Appreciate the help and that it needs investigation, just wondered if there were any plausible electrical explanations for this. If so I will need to get an electrician out quickly to avoid any other expensive appliance damage.
Speak to a few of the neighbours, see if they have had any similar issues. Try and narrow it down to an issue in your property, or a more general/DNO issue.
It's difficult to see how a poor quality installation, without anything obvious, like flickering lights, could have an affect on the reliability of your appliances. Poor electrical installation is likely to electrocute you, burn your house, or keep tripping out.
A very high or a very low supply voltage will affect long term reliability, but this is unlikely and would be a DNO problem, unless the appliances are a very long way from the supply and are wired with badly undersized cable.
It's more than likely to be coincidence. In the six weeks before Christmas, I had a 2year old electric glass hob crack, a 5 year old fridge freezer fail, and a door handle fail on a 5 year old washer/drier.
I have an update on this now.
It turns out the oven is actually still in working order, but the switched socket it is plugged into no longer works.
From memory the socket is wired into the same cooker switch as the 32A hob, which still works and did not trip when the oven stopped working. Therefore something appears to have gone awry between the cooker switch and the socket.
A 13a socket tester does not light at all.
Any clues on how a 13a oven could cause fault like this would be appreciated.
Cpflatman,
Lucien Nunes,
