- Aug 12, 2017
- 14,335
- 20,734
- 3,557,381
- 51
- United Kingdom
Had a look at a job today to replace 5 x 1000W halogen floods with LED equivalent in a big agricultural shed. 4 inside, 1 outside, all high level.
The 4 inside are controlled by a 4 gang grid switch, across 2 circuits on 16A breakers.
The lights themselves have a 13A plugtop and are plugged into 13A sockets controlled by the switches.
There has been discussions before about using general purpose sockets on a lighting circuit, but the consensus seems to be, it’s alright if it’s something like a tv aerial in an attic, or whatever.
Should I leave as is, or change them to 5A plug/ sockets?
I will be looking for LED floods with same lumen output as a 1000W halogen.
Anyone got recommendations?
