Discuss Replacement screw on lamp shade for bathroom spotlights required UK in the Lighting Forum area at ElectriciansForums.net
Hi all,
Looking for 3 replacement screw on cyclinder light shades for a bathroom spotlight. I believe the spotlight I have is Float Brushed Chrome effect Mains-powered 3 lamp Bathroom Spotlight | DIY at B&Q - https://www.diy.com/departments/float-brushed-chrome-effect-mains-powered-3-lamp-bathroom-spotlight/1681184_BQ.prd
I would really appreciate any guidance on where I can obtain three of these shades. They are approximately 11cm in height and 1cm diameter with a screw fitting at the top. Please see photos below.
I am in the UK.
Many thanks in advance
I see that this is a G9 fitting, and that the B&Q ad. says it's LED compatible.
I have a fitting over the basin in my bathroom that uses two very similar, if not identical, shades and find that even the lowest rated G9 LEDs (2.2W) tend to cook and fail in a not very long period of time.
buy a complete new fitting.
use the shades and keep the rest of the fitting in a box incase the fitting fails in the future.
that's what i was going to suggest before i read your post.
Reply to Replacement screw on lamp shade for bathroom spotlights required UK in the Lighting Forum area at ElectriciansForums.net
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Hi, I’m a DIYer I am trying to replace an outside PIR lamp which is connected to an internal fused switch in the hall. Removing the cover of the...
Hi I have three rooms. Two rooms have two lighting points, each with 3 GU10's coming out and 1 room and one point with 3 GU10's. So I have 5 of...
11K
Another long one from me ... I hope that it covers all the bases and is a more thorough approach to the subject. It is my first design work so...
6K
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
