Its vynckier on the main board?I'm intrigued as I know most consumer unit brands from sight but your main one is puzzling and could be an ad hoc made-up unit judging from the enclosure and the numbering sequence. Can you post a clearer head on pic just for my curiosity.
Agree with others. You do need a good EICR on the installation. Looking at your pics you seem to have a single RCD covering your circuits. If that's working correctly then that will offer a degree of confidence regarding safety, but with a very big BUT !!
Definitely get the EICR conducted, research the guy NOT the company doing that EICR (Its that man on the tools that counts). Don't be afraid to ask him for qualifications, and experience.
Do NOT go for the cheapest quote (false economy) and if you like, post the findings on this forum.
There are some genuine, experienced, guys here who will smell a rat if there is one.
Oh yes!! No code 2s for plastic consumer units, have seen a few of those in my time.
That was another fear, we have just finished all bar 1 room!Just a little bit of input, non electrical.
it may b3 worth stopping your redecoration as if you do need a rewire you will hav3 5o redecorate all over again.
Is it plugged into the socket or a wire spurred from it. Is it fused down do you know?Don't think I'll get the guy I had to install the outside light as that even I think was a nasty job. He does the EICR's, when he installed the light he never mentioned anything about the fuse box plus the outside light as far as I am aware is not on a RCD as this taken from the tumble trier socket
He has cracked the socket and the cable comes out thro the wall . No fuse as far as I am aware . I will post a picIs it plugged into the socket or a wire spurred from it. Is it fused down do you know?
Cost me around 50 or 60 quid can't remember . I was not here, when I came home wasnt overly happy as he used white pipe outside which I think looks cheap and the light is so high I cant get the screws off the cover to change the bulb!I think you may be right in not getting this guy to do the EICR.
If you mean the smaller board that only is for the consavatory and outside summer house nothing inside the house is off that just the main boardOn one of your boards there is RCD protection for sockets, so the outside light might be protected As it’s spurred from the socket.
so it may be he has done the job correctly. I was a bit quick to judge.
