Discuss Rcbo tripping in the UK Electrical Forum area at ElectriciansForums.net
@Vortigern has made a very valid point
nowhere in the original post did it say that the main isolator was still energised.
both myself and others have in our own minds assumed that it is energised because the fault described would in most circumstances require the power to be on for it to manifest itself.
@Sonia Norman
if indeed you are testing Ze with the main isolator switched on, I hope you have learnt something from the posts.
if in fact the main isolator was off then there is something unusual going on there, possibly to do with a current flow between N and earth via the rcbo fly lead .
@ everyone else, remember that we are all human and don’t get everything right all the time.
I am sure if we look back at our own mistakes and failures, the odd one will make us cringe.
I for one can look back at a couple of events that didn’t go horribly wrong, more due to good fortune than perfect methodical working practices.
Very true, I had made the assumption it was still energised. There might have been something else allowing the RCBO to trip even though the main power was isolated, though in itself that is worrying!
@Sonia Norman
Reply to Rcbo tripping in the UK Electrical Forum area at ElectriciansForums.net
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
I have a ring cct (2.5mm ) in my cabin which is protected by a 20amp RCBO. This has been in existence for over 3 years with no issues. I recently...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
