M
multimick
Always fit live boards now mini rcbo no earth never had a bad one. spd built in if you want it
Knocking out holes that the manufacture built into the design is one thing drilling new holes into the manufacturers enclosure is a completely different thing, but don't get me wrong, my original comment was said with my tongue firmly in my cheek,No difference drilling extra holes in back of enclosure to knocking out 20 mm holes in bottom and putting grommets in
So what do you do for glands or conduits when knockouts are wrong size/place?Knocking out holes that the manufacture built into the design is one thing drilling new holes into the manufacturers enclosure is a completely different thing, but don't get me wrong, my original comment was said with my tongue firmly in my cheek,
Drywall anchors far better imo. Like theseI would have used plaster board rawl plugs, the metal screw in ones. Man, you've gone to a lot of trouble for the sake of a rawl plug ?
Or possibly screw a piece of ply on to the wall into the joists, it would only be a little bigger than your original board.
Why didn't you say they were umbrella or brolly fixings you were linking toDrywall anchors far better imo. Like these
To avoid regional differences in what things are called. I should have called them hollow wall anchors. But if I ask for a box of dry wall anchors at a certain size and that's what I get. If I ask for umbrella or brolly fixings I'd get a confused stare.Why didn't you say they were umbrella or brolly fixings you were linking to
If I asked my fixings suppliers for drywall anchors the response I would get is which ones do you wantTo avoid regional differences in what things are called. I should have called them hollow wall anchors. But if I ask for a box of dry wall anchors at a certain size and that's what I get. If I ask for umbrella or brolly fixings I'd get a confused stare.
Same as 100A Service blocks, we call them Isco's, you call them Henleys
The post that sparked this interesting debate, about regional variation of terms used for fixings intended for use on hollow walls, also included a link to the specific type of product being reffered to.If I asked my fixings suppliers for drywall anchors the response I would get is which ones do you want
