Guest viewing is limited
wiha or wera are popular. best i've ever had for reliability is irazola, now bahco, but they are quite long and awkward to fit into some toolbags.
Ive had 4 sets of Wiha (Tel is about to receive all my spares this week:) and they have been brilliant. Pound for pound they are the best insulated drivers on the market in my opinion. If you want to spend a bit more you can try kleins or Irazola which are equally as good but twice the price of wiha
If you are carrying out board instals make sure whatever you buy has the insulation on the blade far enough up the shaft to allow the blade to reach the terminal screw.
Plenty available with slimline shafts that are fully insulated, but sufficiently narrow to allow blades to get where they need to be.
PZ/SL1 and 2 + and - blades are generally full width of the terminal screw and have a difficult time accessing the small opening if the insulation is close to the end of the blade, doesn't happen on all units, but some RCBO's have deeply recessed terminals.
I would get a cheap set from one of the sheds when they are on offer so you have one of everything,
If you're really lucky you'll get a neon screwdriver for free - which makes a good bradawl for poking holes
Then see which ones you use most and spend a little extra on good quality versions of those. I try and colour code the types so that I can tell them apart easily - (better ones do also have markings on the top of the handle to make finding them in the bag a whole lot easier).
A good flat head for faceplate screws is a must - many of them don't properly fit the cheap screws on some cheap fittings. The Klein one I bought for that has more than paid back its value in time saved...
Alternatively, buy two sets as otherwise when you are on a job, the one you need will always be at the other end of whatever circuit you're working on!
I've got 3 sets of Wera interchangeable blade drivers.
The last one I bought was a torque driver set at Elex 2017, slimline blades, and also added extra PZ+/- blades
For about £5 each. Set was about £120 I think.
set in LIdl's . stupidly cheap. maybe not the best quality but as a starter for an apprentice, no brainer.
having said that, i bought a set 5 years ago, £6.99 for 6 or 7. been used and abused but still in decent shape.
A few years ago I once bought a set very similar to this...
For about a tenner to see if they were actually any good, and to my surprise are ok. They don't come out very often other than the small flatheads I sometimes keep in my pouch.
But considering the cheap price have lasted quite a while.
My Wiha set is still the one I use most but the cheapo ones are handy as back ups or to poke plasterboard etc
I use a cheap Lidl set for general use. Had them a few years and still good. Got a Wera/Wiha (can never remember which) set for the "posh stuff".
Grab yourself a set or 2 of the Lidl ones and you won't regret it.
with the likes of wiha and wera. you're paying over the odds for the name. like our new kettle. it's a smeg. bleeps and farts with pretty lights. water boils no better than a £15 cheapo from aldi.
This set is usually a pretty good start with Wera - 15 blades (inc PZ/S) & 2 handles for £40 odd.
Of course Amazon price is fairly high today.
I've got a "Wickes Professional" branded screwdriver that's great for plate screws/terminals... I've been using it for years and years... and still going strong. I think I grabbed it quick somewhere as I was without the van/tools and someone needed something fixed.
Lidl weekly offer ends today. May still be some in your local store.
I dont think they should advertise that they "allow you to work on live parts up to 1,000v"
Thats just going to give Joe Public false confidence in DIY electrics
The only real issue I have found with the cheapo £5-10 vde sets is the pozi2 tip tends to round off very quickly. the flat heads seem to last a bit longer. But for a fiver what do you really expect
I think I have tried most brands of vde screwdrivers and never really had a favourite , I think the only big name brand that I haven't had a set of is Facom
Only recently learned that Facom is a Stanley Black and Decker brand. Not sure why, but this surprised me.
My favourite (work) trousers are rather appropriately branded 'Scruffs' ?
Comfort combined with reasonable prices.
I don't think they should include a neon screwdriver and call it a voltage tester as well.
why not. every other maker includes one. wiha, wera, draper et al.
I have my set I started college with, moved on to Wera but they still get use at home.
LukeD
Supporter
Which brand new Insulated screwdriver set is worth buying
Electrical Tools and Products
LukeD,
Dustydazzler,
