K
kiwiscole
I wish to run a 12v fan in the cabin of my car, only while the engine is running.
I wanted to use the alternator charge wire, connected to a relay, so when it switches off, the relay opens. But my car doesn't have such a wire on the alternator.
I'd like to use the oil sender wire.
This is a negative switch.
Can I wire a relay so that when the oil light goes out, the circuit opens? Either positive or nagative output is fine.
Thanks.
Thanks.
