Discuss Negative switch relay in the Auto Electrician Forum area at ElectriciansForums.net
I wish to run a 12v fan in the cabin of my car, only while the engine is running.
I wanted to use the alternator charge wire, connected to a relay, so when it switches off, the relay opens. But my car doesn't have such a wire on the alternator.
I'd like to use the oil sender wire.
This is a negative switch.
Can I wire a relay so that when the oil light goes out, the circuit opens? Either positive or nagative output is fine.
Thanks.
Hands up who remembers the good old days when if you were selling a car with dodgy oil pressure you'd wire the warning light into the ignition warning one instead....
I think he wants engine running, not ignition on. TBH I can't think why, as you're not really supposed to leave the ignition on with the engine not running for significant periods.
Hi,the make and model of the vehicle is important,in deciding the best method of achieving what the OP wants.
Reply to Negative switch relay in the Auto Electrician Forum area at ElectriciansForums.net
Hello folks, So my van got found after being stolen ;D Now I'm installing my own alarm on the van which is triggered when a door is opened. Im...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
Hello! I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to...
