- Reaction score
- 0
Hello!
I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to energize the accessories, and the fuel pump, (I believe that's all I'd need with the switch,) and then hit the push button to start the engine... pushing it again would kill the engine, then flip the switch to kill power to everything. I've run most of the wiring, including a relay, and a ground, but haven't connected anything yet. Wanted to get an expert's viewpoint first, cuz all the videos seem to contradict one another!
A simplistic diagram depicting which wires to run where would be most helpful! What I have so far is a standard relay, and wires run to the starter, the battery, a toggle switch with an inline 20amp fuse, and a ground. I've yet to include the fuel pump,(can I tag into an existing line, or go from the fuse/relay box?) And what (if anything) do I need to unplug/disconnect to make this all function correctly? It's for my 2000 Bravada, (I've already successfully bypassed the Passlock ll Hall Effect sensor.)
Thank you for the assistance!
In case I run into (more) hacking into my phone, you can email a diagram to me too...
[email protected] (I know, it's a stupid email but it's true...lol.)
Thanks again!!
Thanks again!!
