Discuss Replace shower - part p or not? in the UK Electrical Forum area at ElectriciansForums.net
Rockingit
Mentor
Supporter
Reminer please as I've not been paying much attention to Part P changes - assuming that an existing install meets 2018 EICR 'requirements' - would a replacement swap of a faulty shower unit be notifiable works?
Presumably though if the circuit wasn't up to scratch - rcd/ratings/whatever then it would be notifiable after correction?
I would say no even if you add additional rcd protection or changed the protective device. If you rewire the circuit or significantly alter it then yes.
Pedant! ?
I know the point you're making is that ALL electrical work in a dwelling has to be compliant with Part P of the building regulations, a point sometimes not fully appreciated.
But come on... you know full well the intended question was "is this classed as notifiable works, under Part P of the building regulations?".
Pedant! ?
Yes, I do, but the conflation of Parts P and 3(12) of the Building Regulations ought to be resisted because it can lead to, as you say, a lack of appreciation that all electrical work in a dwelling has to be compliant with Part P.
It was quite clear what the OP asked let's not turn this into a ramble over what is Part P.
Part P says any alteration to a circuit in a special location, surly replacing the shower is an alteration, so would be notifiable?
Is replacing like for like an alteration?
Sorry I have just done something I hate most on here and not answering the point, My point is I don't think it is an alteration and therefore does not need notifying.
You're not altering a circuit, you're replacing a piece of equipment.
Keep reading the same page...
Non-notifiable work
2.7 Regulation 12(6A) sets out electrical installation work that is notifiable. All other electrical installation work is not notifiable – namely additions and alterations to existing installations outside special locations, and replacements, repairs and maintenance anywhere.
Non-notifiable work
Interesting,
I read that as replacements outside of special locations,
Reply to Replace shower - part p or not? in the UK Electrical Forum area at ElectriciansForums.net
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
