N
nicebutdim
Amazon have kindly given me £10 off £25 spend. I don't care much for tat, so figured it might as well go towards a new tool.
As I can't list every tool in my possession, I'd welcome suggestions for stuff that might not be immediately obvious, but very useful and worth having (in the region of £25-£50ish).
Do you have the Kewtech Lightmate kit? (I've got the cheaper TIS one but Amazon don't seem to do that!)
Great shout!
Looked at them many times, but never pulled the trigger. Didn't realise TIS made a version as I'd only seen Kewtech and Socket & See.
Just noticed Amzon themselves are £10 more expensive than other sellers and the voucher can only be used on purchases from them ?
Knipex Installation pliers
I actually like the look of those and had been thinking about a new set of long nose pliers as my own aren't great. Fancied my first knipex tool, but don't like their long nose pliers - I like using that open serated section for bending the end of conductors, but Knipex don't have it. CK long nose look like my kind of pliers, but not sold by Amazon.
Those installation pliers have a narrow nose, open serated section (whatever it's called) and shears - pricey, but might treat myself to a pair.
Knipex ergo strip, Klien conduit level if you do a lot of pipe. Small stabila level that fits inside patress', Bosch multimaterial drill bit set, keyring magnetiser, Superrod double ended supergrip (crskd-1114)
Great shout!
I got mine about 6 months ago. "TIS LIGHTAD" on ebay - they are currently £50 delivered. Doesn't help you with an amazon voucher of course!
They seem to have slightly longer shafts than the Kewtech ones my mate has which helps. I have to say they are getting used an awful lot. One handed R1+R2 at light fittings is nice.
Ergo strip I've looked at many time, but could never quite decide if it would ever get enough use.
Mini level I have the Stanley 042130 - bit larger than Stabila mini, but liked that it had horizontal & vertical. Slightly wider than 1G pattress.
Drill bits coming out of my ears.
Small magnetiser is very hady - provided it's not at the bottom of a box.
Have small, cheap rods & CK Mighty set, but also recently picked up Super Rod CRSK12 (comes with 2 sizes of supergrip) as Amazon were running a bargain price.
Can't believe I never saw that TIS set before and price is much better than either of the other options.
A decent set of hole saws or wood bits
Literally have thousands of Metabo holesaws, supplemented with a few cheap Erbrauer for larger sizes.
Spade bits are a subject I've never properly addressed. Currently using a cheap Dewalt set, with several brands added as replacements. Bosch speed cut seems to be highly rated, but I generally have 12v tools to hand and always felt that speed cut would be a bit aggressive for them.
Not sure if I've found anything suitable to buy from Amazon on this occasion (possibly Knipex installation pliers...), but appreciate everyone's thoughts and can now add a few more tools to that ever expanding and contracting list ?
Dilog, beha amprove, Martindale and a few others also do them
The Knipex is great for flex, does a very nice job without nicking any of the cores...
Don't find the other bits that useful though - For stripping end of cores where limited space I find the Jokari all rounder pretty useful though and nice and cheap too.
I struggle to use it to strip Twin and Earth though, I think you need to get the technique just right...
Never seen light test adaptors from Martindale or Di-Log and can't find htem in current ranges. Beha-Amprobe make top notch gear, but a little spendy for these adaptors. TIS looks like the best option (for me), but that'll be for another day.
Figured it'll be something my miserly mindset considers to be extravagant. Ergostrip always looked interesting, but have a Weicon stripper that does the same job, albeit less quickly. Knipex stepcut looks interesting, but have a couple of pairs of croppers that'll do for some time and, besides, Amazon seem to have trust issues about supplying them to people in NI!
Don't need them but, what the heck, I'll go with the installation pliers suggested by @Pete999 - Amazon price is as good as any for the non-sprung version (don't like the idea of spring and lock) and that £10 off helps me justify this indefensible expenditure ?
Appreciate all the suggestions and, if anyone happens to have more ideas, feel free to contribute as I'm always receptive to ideas for future tool purchases.
knipex crimper for insulated crimps . the jaws are narrower than other makes so you can safely crimp 1 end without partly crimping the other end, and the pressure is adjustable,
I've had a couple of the Kewtech Lightmate kits over the years, but (a) found them a bit large to fit in some light fittings with small shades, and (b) prone to damage or going intermittent esp. if dropped now and again. Then I found this Amprobe kit, where the adapters are so much slimmer and fit where the Kewtech ones don't. A bit pricy, but I wouldn't go back to Kewtech ones now:
I paid just under £67 inc. VAT online about a year ago, but you can easily pay over £100 if you don't shop carefully. They seem quite rugged but I've not tried dropping any of them, the price makes me a bit more careful!
Striped screw extractor set, for when screw heads are stripped by Joe public using the wrong driver or Cowboy spark using an impact on EVERYTHING
Had a few sets over the years, but was never impressed by any of them. I suspect paying a little more might go a long way with screw extractors.
10mm & 12mm plug cutters, for chipboard flooring.
Get around the nails and resecure with screws
There are a couple of other interesting tools for cutting access holes in chipboard flooring.
4" or 5" hole with rebate for plug or plate.
Superrod Cavity Master?
Not sure of names but, of the two that come to mind, one provides a steel plate (presumably requires a little sealant or adhesive) and the other a plastic plug.
I like the idea of cutting around screws, but you still have tongue to cut. I guess access holes are handy when you know where to cut and lifting sections the better option when you don't.
that weetabix flooring is the spawn of the devil, with water pipes tight up against the underside. if i need some cutting out, i get the customer to do it.
you get a little camera that if you drill a 16mm hole you can poke the camera down to check for pipes before ripping through the floors with a circular saw
yes you might hit a pipe when drilling the small hole but it’s less risky than going at it with a circular saw
One of those "ferret" cameras is also on my wish list!
Quite a good way if you need a big access hole , the black plastic spinning thing gives you the correct depth
Was half minded to add to the tool collection tonight, with suggestions in mind from this and other threads. Glad I did as Amazon had Super Rod's Cavity Master kit in a warehouse deal for just over £24. Added a spare Wera #2 Robertson blade & Armeg roofing bolt driver and Amazon gave another £5 off if I used click & collect. £35 & change for the lot seemed like a bargain and I take back (some of) the stuff I've said about them.
Suggestions for useful tools...
Electrical Tools and Products
nicebutdim,
Mikegh,
