N
nicebutdim
Been round every local shop and not one keeps empty vaseline tins
One of the top PITA over the years, the top screw on tungsten halogen fittingsI used to use it a lot for the old external tungsten halogen fittings top screw to prevent it getting welded to the aluminum body!
never had a problem with ones i fitted. threw away the supplied screw and fitted a brass 4mm nut and bolt, with washers.One of the top PITA over the years, the top screw on tungsten halogen fittings
Never thought of thatnever had a problem with ones i fitted. threw away the supplied screw and fitted a brass 4mm nut and bolt, with washers.
Oops.Surely it's 'smirk' not 'smerk'. Not being picky or anything.
I thought it depended on what is in your mouth at the time?Surely it's 'smirk' not 'smerk'. Not being picky or anything.
Brass & aluminium is worse for corrosion than stainless, but if you are not using the tapped thread it is slightly easier.never had a problem with ones i fitted. threw away the supplied screw and fitted a brass 4mm nut and bolt, with washers.
