It might have been “smirk” but thought maybe “smerk” was a local dialect word and I didn’t want to correct them.?
It won't be a problem soon as they are all becoming obsolete!
Looks like I will have to find a new use for the Vaseline!?
@telectrix I was going to say cable tie!
never had a problem with ones i fitted. threw away the supplied screw and fitted a brass 4mm nut and bolt, with washers.
Brass & aluminium is worse for corrosion than stainless, but if you are not using the tapped thread it is slightly easier.
Either way, lube up your threads or pay the price!
