S
suffolkspark
Anybody had any success with cable toners? I've got a job which is full of MI cable, but a lot runs In untraceable voids and there are a multitude of metal boxes joining them to singles and other MI cables, I can see in a loft space a large adaptable box with 9 in, there's a couple of those! I've got a damaged one on a job and am going round In circles checking where it's fed from, was thinking if these really work I can at least narrow it down before aimlessly taking things to bits, everything in the building still works so it could be redundant but it's 30m up on a scaffold so i want to be sure the neutral isn't still connected somewhere and could cause issues down the line!
I have used quite a few and most like the one you have linked are aimed for LAN cables. I have used them to locate circuits but they can only be used for dead cable testing
The cheaper ones i found hit & miss but had a lot of success with this one
IntelliTone™ Pro 200 LAN Toner, Tracer and Probe - https://www.flukenetworks.com/datacom-cabling/copper-testing/IntelliTone-Pro-Toner-and-Probe
Fluke also do a cable locator which is designed for live or dead cable locating but its not cheap at around £600
Fluke 2042 Cable locator - https://www.fluke.com/en/product/electrical-testing/basic-testers/fluke-2042
Be aware that on cables like SWA, MI, FP etc they will only work on the stripped ends (end to end)
If you can get to both ends then even the cheap ones will do the job but aren't so great at detecting circuit mid cable
Using toners have saved me countless hours especially when dealing with a lot of singles and should do exactly what you want if you can get to the joint boxes
Yea I've got access to lots of joint box's so hopefully it will help, I've ordered the one in the link but from cpc, made by flir so hopefully will do the job! Hopefully I can find it or I'll be borrowing some MI gear and attempting my first end in 15 years!
I have one of these, it's actually really good and has had a lot of use over the last year, only bought it because my Maplins one packed up!
Can't seem to get a link for it off Amazon
Oooo that looks a bit nicer than the one i bought, allthough I hate button cell batteries ?
I must admit I'm not a fan of them either, but they are cheap enough, I bought 50 off eBay for about 3quid when I bought the toner and I've still got about 15-20 left so it's not been a problem.
Don't leave the cheapy cells in equipment or they will likely leak at some point. Keep a regular check on them.
@pc1966
This is a good point, the croc clips would need to be on the conductor to work as would the receiver due to the copper sheath. The one I linked to would not sense through the sheath.
Great job for data cabling
Do the toners work on MI ?
I imagine if i clamp on the outer copper the whole building will ring, but HOPEFULLY if I go L-N with them neutrals out at at board I may have have chance. It was only £20 so not the end of the world if it doesn't, watched a David savery video of him using one tracing circuits in a house so it may be usefull
suffolkspark,
suffolkspark,
