What's a durable brand of vde screwdriver ?
Something below the knipex price point
Which is more useful in a vde set, Pozi or Philips ?
15 quid at the moment and worth every penny , pound for pound they are the best vde drivers on the market
Changing blades is no great hardship and means you can carry a few without taking up precious pocket space.
Do you guys use Screwlox in IE? If so, I'd be inclined to opt for Phillips.
Not really sure on screwlox
Mostly pozi 2 for fixings and probably Philips for terminals (after flathead) I'm guessing
I still have squaredrive screws from misadventures with them, waste of time easier to stick with pozi for fixing
Cross the border and you'd come unstuck within minutes - basically every fixing will be Screwlox ?
A while ago I was cursing square drive , I went to a job and the previous person had screwed all the flooring down with square head screws
I had to waste an hour driving to screwfix to buy some square drive bits to get the screws out
At least I have the bits now
Next time you'll get to see the benefits ?
Half the reason I dislike them, got called out to unscrew a box
I find pozi just more convenient to fix and less time swapping bits as most existing fixings are pozi ime
Pretty much - think there is some tiny difference, but they're interchangeable.
Only seen Robertson drive in Canada, pretty much the comm on one there. I think the special feature of the Robertson drive is the slight taper, so depending on screw tolerance the drive bit sits slightly lower or higher but always tight.
Gedore VDE Slim screwdrivers. They are AMAZING quality. Outstanding in every department. Facom's were my go to as high end drivers but these are another level of elite tool. They make all the go to brands like Wiha and Wera look cheap as anything.
Tried a Boddingtons VDE driver and it's rubbish.
Facom Expert are great, or the Wiha ones often on offers in screwfix etc. I've not had to replace any through a broken tip for me or lad who works for me in either of those
Looking at that and the 'socket and see' contact testers
I have the Socket & See EPF 30 (think it's now called EPF Pro). It's good, but fairly chunky - as such it doesn't generally find itself in my pocket and is infrequently lifed from the box. A 2 pole tester is easier to carry (around the neck) and many of those will detect voltage from one probe.
I see kewtech do one too
Not in a panic , I reckon the non- contact will do for 90% of that voltage indication type testing
A little behind the times with the hand cranking , about 16€ might do me for a bit of troubleshooting
This was my go-to meter for troubleshooting , an eagle Megger, just died recently
Lol cost about 75 I see Farnell have a rebadged version for nearly 5 times the price
Good one alright
As someone said in relation to ac clamps i think
,it can be useful to see the dial flickering rather than the digital display
Ive seen Gedore super cheap in many countries >Wish I'd bought some !! Then again ...30 years Ago .Facom was sold in most French supermarkets cheap
Facom's now are suspect, seen loads of reviews of them saying the tips are very weak and snap often. The ones from a few years back were awesome though.
The Gedore....i can't even describe how good they are. They have chunky sort of square-ish barrel handles and they are so sturdy. I won't use any others now.
Belters. Didn't think they would come in that useful but already used a couple in the first few weeks i've had them.
Add a set of nut drivers for your impact, but make sure they aren't magnetic.
Seems a while since I added anything here...the nut drivers are great, and as are the step-up. step-down adapters form 1/4 to 3/8 to 1/2"...actually many great adapters out there.
May have mentioned this before, but as I have used it a lot this week, I'll nominate the Dremel 2000 versatip gas powered soldering iron/cutter/heater whatsit.
Taking the catalytic convertor off, and adding the hot-air tip, with guard, allows you to use heat-shrink in small spaces without a flame, and as a bonus, ignoring the wide flame-spreader. it makes a great job of scorching a créme brullé...
Yes, I need to get out more!
Seriously though, I've used this on one refill of gas, all week, and it's just amazing for heat-shrinking to cover joints and to identify cables on SWA etc.
My fun project was to see if a cordless Dremel multi-tool was a good and easy way to prep SWA...it is! Needs a bit of practice, but actually, using some off-cuts, it went really well.
However, I still prefer the junior hacksaw approach. Those with good hand-skills will be able to dremel the sheath and armour, strip the sheath...maybe a good idea for some? Just remember to choose the right accessory/cutting wheel, otherwise it's like doing terminations in a CU with an impact driver...
Just a quick word on H&S/PPE...I was driving some long screws this week, 150mm pozi 3 screws, with my impact driver. They were easy, but...driver bits can break, or shatter even...dug a shard out of my left lower eye-lid...3 mm up and it would have been in my eye...wear goggles!
I'm embarrassed, because i did the same thing a year ago, and I should have learned my lesson. However, we think the bigger bits won't break...but they do.
Always wear safety specs!
and always wear safety specs!
Whatever you are doing, wear them if there is ANY chance of injury, however remote.
Norwich
Trainee Electrician
what are some tools that were worth the price tag?
Electrical Tools and Products
mrsparky,
Zimmerin,
