The most important thing to do first is to stop the Energy supplier from billing the O.P
If the O.P is on a similar rate to me per kwh then the outstanding for the 40000 is around £6700.
OFGEM should be able to at least get the supplier to hold back the charge for now on the basis, as Littlespark's example, it would have been almost impossible for that usage during the period.
However just a warning,the energy supplier may argue that the O.P has been sending under readings in and the 40000 is an accumulation of the outstanding.
AS the Energy supplier have closed the case that's perfect for an OFGEM complaint as the supplier will no longer discuss it and don't appear to have made any reasonable attempt to sort it out.
Whoever fitted the Isolator also appears to have replaced the meter to consumer unit tails ((brown / blue cables) and the tails from the fuse cutout (lower right) to the meter.
As the meter and the tails to the cutout are the property of the Energy supplier then whoever did that work, which involved cutting the meter seals and moving it, MUST have had authorisation from the Energy supplier.
If they didn't get it then the Energy supplier also needs to chase up why the work was done without their knowledge, initially through the Landlord who will have paid for someone to do it.
