mattg4321
1,650
2,259
104,788
South East UK
As above, SDS drill sparking and intermittently down on power. Sparking between brushes and commutator.
Brushes and springs seem ok, but have quite a curved surface at point of contact. Loads of meat left on brushes.
Will changing brushes fix it or is it dead?!
change or redress the brushes
sounds like the commutator is Knacked from your desciption so yeh its a scrapper.
Dom't agree get it serviced if you can't do it yerself , save some scrotes, scrap it my bum.
I am not sure if he means the commutator is curved or the brushes. If the former then it's knacked. If the latter it's still knacked as the commutator must be rough to cause the brushes to curve.
Brushes are curved. The middle is more worn than the edges.
pics of commutator helpful. usually you can see any signs of damage ibetween the segments.
Brushes are curved.
Yeh I had this pic that they were worn on the edges and not meeting the commutator. It's a well known fact if you try to sell a drill in a second hand shop they switch it on and if there are sparks on the commutator they will not buy it. Of course they are curved as they contact the commutator but the sparking usually means Knacked. However I have been known to clean the contact points and new brushes and hey presto problem solved. I am not for chucking tools unecassarily
If the brushes are sliding freely in their tubes, the copper braid hasn't caught up somehow, restricting their movement, and it's still sparking excessively, then it's knackered.
Reactions: mattg4321
Just as I thought really then. I’ll try and get some pics anyway though at some point
a bit of sparking is normal. if the armature is knackered, then generally the drill runs slower and sometimes stinks of dead fish. a new armature can be got for around £30 - £40 for a lot of drills. expensive drill can be worth the repair.
Pictures and video ad promised. Think it's dead?
  • IMG_9676.MOV
    7.3 MB
Unfortunately I don't think anyone can open pictures today
Can't see too much as I can't download the piccys but looks like a dirty commutator. Try cleaning with Qtips and alcohol. Springs on brushes look ok so don't think it's lack of pressure unless there's something holding back the brush when it's in the drill.
Reactions: suffolkspark
mattg4321
South East UK
SDS drill sparking..
Electrical Tools and Products
mattg4321,
Sparkgap,
