A
A3113684
Hi everyone
I am currently renovating a small old cottage attached to our house. On the outside is a sort of electrical box with a key hole that runs inside to another box with a key hole.
I believe the cottage was rented out in a previous life.
Any ideas what it is? And cab I just remove it?
Thanks in advance
Kev
Looking at the inside box, mentions “line” and BS6301…. Quick google of British standards says 6301 is something to do with telecommunications. But very outdated now.
The outer box looks like it’s connected to a mains power cable, so that needs tested to see if it is powered, or disconnected.
Agree. The first one is a phone socket that only allows 999 calls when restricted.
The 2nd one looks like it needs a careful look at.
I don't know what the second one it - could be anything. You'll need to investigate where in the electrical system it connects to and remove it.
The first one is for restricting use of the phone line. Basically, it connects into the phone socket behind, the phone plugs into the front, and when in restricted mode if limits what numbers can be dialled on the phone. Chances are it's so old that it only does "pulse dialling" and will allow anything to be tone dialled. Just get rid of it.
As there’s only 1 cable coming to the 2nd one, it’s a switch for something. Do you have any roller-shutter doors, outside lighting, anything that seems not to work?
It really needs a sparks to have a quick look at.
Reactions: Jim_e_Jib
I wondered if it might be something to do with security, given the Logo? But on T&E 🤔?
That is the Klöckner Moeller logo.
but does it run a klock clock for the moles , telling them when it's safe to make a mloehill?
Reactions: loz2754 and DPG
Klöckner Moeller is simply the manufacturer of the plastic box the control is built into.
You really need someone to come out and test it, disconnect it, and remove it.
Is the outside switch an isolator for an external phone bell / sounder
Reactions: timhoward
Electrical box with key hole?
UK
A3113684,
telectrix,
