- Dec 2, 2019
- 1,782
- 2,586
- 3,688
- United Kingdom
- Business Name
- F. H. Electrical
So upgrading to KT66dl from KT65DL. I want therefore to recoup some of the costs. I am looking for £350-400 range +postage. Comes with original case and PAT adaptor. Set of leads, crocs and probes as per usual. If you compare functions between the 65-66 the 66 only has two more functions related to EV testing. I don't really know if I needed the 66 but tool tart syndrome! It is calibrated to Sep '22. Never had any problems with it. See photos. It also comes with the Kewtech PAT adaptor. A nice simple and reliable Multi Function Tester. P.S. Also comes with the optical to USB adaptor to download test results to computer. Of course it comes with the original manual and paperwork.
