Thanks for your advice. will get this bit and maybe have to hunt around for some more solid ground. When I was running my electrical business I vaguely remember you used to be able to buy something like a clay to goa around the rod - will have to have a look...........Linian make some very handy accessories here. One is a rod-tip that is basically a masonry drill:
And they do a matching SDS driver to make it easier to drive in:![]()
LINIAN Earth Rod Pro™ Bit, Carbide Tip (1LERPB)
LINIAN designed and developed a simple and effective solution that bores through hard top layers and underground rock to achieve a secure Earth Rod connection first time. This innovative, patented new solution offers installers confidence that they will be able to easily install the rod the...linianclip.co.uk
LINIAN Earth Rod Pro™ Driver (SDS+) (1LERPD)
With the rise of new challenges like 5G, EV charging industry, Big Data installers are completing, even more, earth rod installations than ever before. However, this can be a laborious task, often involving a large hammer, a lot of effort, and hopefully a bit of luck. It doesn’t have to be this...linianclip.co.uk
If you can get 8' in (two 4' rods with coupler) generally you get better results as ground tends to retain moisture lower down. However, if it really is dry rocky stuff all the way you might want to consider a trench to somewhere that has soil for a rod with better chance of success.
