notmuchgoingon86
I purchased a chandelier from Aliexpress (China) that came with bi pin G9 LED bulbs (3W equivalent) (pic attached). I asked the seller if this was dimmable and he said NO the bulbs are not dimmable. Apparently China uses cheap non-dimmable bulbs. But the seller told me I could purchase dimmable G9 bulbs and pair them with a dimmer switch and it would work. When I use the bulbs the factory sent me and hook it up to a normal switch (no dimmer), the chandelier works fine. When I replace those bulbs with dimmable G9s, I hear a loud pop and the light doesnt work. I have not tried hooking it up to a dimmer yet, but what is going on?? Is the pop because I am not using a dimmer with the G9 bulbs? Should that matter? Anyone have a clue and how I might solve my problem to use dimmable G9s with a Lutron dimmer. If so, what Lutron dimmer should I use? Meastro or Diva or something else that can handle the low output of the LEDs when dimmed? Update, I ordered a different G9 dimmable bulb (dimmable) and with a regular switch it came on (no pop) but at a very very faint level. Will this change if I add a Lutron dimmer? Thanks.
, eg (these are 5W not 3W):
