- Jun 29, 2019
- 2,282
- 2,223
- 391,788
- United Kingdom
- Other
- If other, please explain
- Retired Electrical / Electronics Engineer, latterly Quality & Regulatory.
Hi notmuchgoingon86Original G4 bulbs (non dimmable) from China work fine. Chandelier works. If I had a dimmer attached the dimmer gets fried.
The link you provided a while back shows you bought bulbs rated at 12-24volts, which you put into a chandelier running from the mains.
that is why they go pop. They are the wrong bulbs.
To achieve your goal, you need dimmable G4 220 - 240V (or maybe 120V if that is your mains voltage) bulbs.
Good luck with your search.
