I don't have a regs book to hand but I'm pretty sure that doesn't say 'nothing must be within 300mm of a water point' or anything to that effect.
There is no specific requirement for a distance between electrical outlets and sources of water, but advise that you allow at least 30 cm from water or heat sources, where possible.
A point at which humans and water mix freely at room temperature!, I guess it comes down to interpretation of the regs.
To make the filter changing 'idiot proof' for want of a better expression, simply replacing the existing socket with a weatherproof unit designed for outdoor use would be a simple and inexpensive solution.
Along with mounting up the wall a bit :D
markitect,
Dave OCD,
