512.2Ask that electrician to quote an actual regulation number and you will find that they can't.
Can you expand a little for those of us that don’t keep the book at hand 24/7512.2
Equipment shall be of a design appropriate to the situation in which it is to be used or its mode of installation shall take account of the conditions likely to be encountered.Can you expand a little for those of us that don’t keep the book at hand 24/7
512.2
There is no specific requirement for a distance between electrical outlets and sources of water, but advise that you allow at least 30 cm from water or heat sources, where possible.I don't have a regs book to hand but I'm pretty sure that doesn't say 'nothing must be within 300mm of a water point' or anything to that effect.
Years back it was always a necessity to be 300mm from stop cock/gas valve for MBPCI don't have a regs book to hand but I'm pretty sure that doesn't say 'nothing must be within 300mm of a water point' or anything to that effect.
To make the filter changing 'idiot proof' for want of a better expression, simply replacing the existing socket with a weatherproof unit designed for outdoor use would be a simple and inexpensive solution.
132.5.1512.2
Start with the fundamental and build out to 512.2I have visions of a sparky standing in the dock and quoting your statement.Anybody changing the filter can see the socket so should take precautions not to get it wet....sorted
