file:///C:/Users/Tom/Desktop/SeaEngine/SEAPOWER48.jpg
Once all the bubbles are full of air, all you need to do is fill the lowest one to keep all the other air bubbles pulling together multiplying the upward force.
I have said before, and i will say it again,
If you truly believe in your wonderful design, then simply build it and prove to the world either with a scale model or a full scale working machine.
I have no issues with people that want to think out of the box and that is how innovation is done.
however, i feel you have nothing more to add to the argument that it might work or as you seem to believe, it will work.
build it and prove me wrong or clear off and stop bothering us with useless fantasy.
p.s. if you cant find a suitable engineering company to do it, i will arrange and build it for you.
estimated cost is £100 per foot of water depth you want it to work in.
£650,000 is a good estimate to work with.
He can't reply ....... his computer lost power
will work if you install a steam engine as a source of energy. unfortunately Fred Dibnah is dead , so you're on your own.
I have heard that same, "no it can't" before and in every case no one could produce "any" evidence to show it can not work.
My guess is they don't have a clue.
It's for you to prove that it does work. Not the other way round.
Can I ask what response you have had from other people/forums/ etc that you have asked? It's a scientific engineering question rather than an electrical one.
You've also responded in the same manner in each of those instances.
I get that you're convinced of the availability of free energy, which can be obtained with no additional input and no losses during extraction, but you seem to be missing a few vital points.
If someone reading your threads was in a position to fill in the blanks, what makes you think they'd hand that information over to some random person on an internet forum.
Maybe your ideas are ingenious and everyone here is too thick to recognise that.
Maybe everyone here already benefits from an abundance of free energy, but understands the risks associated with open dissemination of that information... or we're too greedy to share it.
Maybe your proposal isn't feasible.
Regardless of which of the above possibilities rings true, continually posting the same questions and then engaging in argument doesn't appear to be furthering your ambition, so I guess it all boils down to the same thing - go it alone or give up.
I'd really like to see you build a working prototype, but fully understand why you might choose to keep future research confidential.
Good luck in your endeavours.
There is no free energy in this process. You must continuously add more air at the bottom for it to continue. What I believe makes this work is the unifying process. In the illustration ten (10) balloons are pulling and to maintain this unified process all that you need to do to continue is add one (1) at bottom.
Exactly right, the secret is how you fill the bottom balloon at 19Bar, this is the crux of my patent, there is a little known creature that is capable of using the latent heat of seawater and breathing out Co2 at 19.2 Bar. The creatures are proving a little challenging to convince BP they can reliably delivering their end of deal. Sadly BP are currently holding back until their due diligence proves i have a reliable working relationship with said creatures.
Due to language barriers the BP lawyers don't understand them, negotiations continue around the selection of a mutually acceptable translator.
Wish me luck
Welcome to the forum…..
And what did you get out of the discussion….. apart from;
“It will work”
“No, it won’t”
“Yes it will”
“No, it won’t”
Let me re-phrase that for you:
"I don't understand basic physics "
"Here's a clear explanation of why it won't work "
"I think it will because I don't understand basic physics "
"Here's another clear explanation of why it won't work with easy to understand examples"
"Perhaps, but I don't understand basic physics "
I remember this thread went round and round much like the bucket system didn't :-)
Heat pumps certainly work, but they're not "getting anything for nothing".
They work by cooling the outside air and transferring that heat inside. Fortunately there's a lot of 'outside', so a bit of cooling is not a problem.
Absolutely.
For anyone interested in perpetual motion I recommend having a read of Joseph Newman's stuff. Prepare to be entertained but ultimately disappointed (obviously). Much of his idea relied on flywheels of increasing weight - I imagine by now he must have one that weighs the same as a small planet!
Heat pumps might work in theory but so do a lot of things, I've yet to see one that works at all without costing the owner an absolute fortune in electric.
There was an estate near to me called the Stamford Brook estate in Altrincham that was supposedly the next big thing in cheap heating using these things, it turned out so bad it made it all the way to parliament. People that rented were just upping sticks and leaving after a couple of months of electric bills, it was cheaper for them to pay the outstanding rent that it was the electric bill.
Then there is my plumber mate, he wants to get into installing heat pumps so made his own home the "show" job you need to provide. Massive extension all done to the latest regs with UFH and insulation everywhere, the rest of the house brought up to latest regs, new windows, insulation etc. The most sophisticated heat pump set up I've ever seen yet still he has to constantly put the immersion on to get anywhere near a suitable temperature needed.
He should have asked me for advice - if you are using the air from outside to heat your home, if its cold outside then its going to be cold inside, shouldn't take a genius to work that one out.
The powers that be rely on you hearing or reading one thing, but thinking something entirely different.
Heat pumps are very efficient. That does not mean they are cheap to run, and while the price of electricity is many times the price per unit of oil or gas, they won't be.
Exactly!
We have a couple of air conditioning units - which are basically heat pumps, they do provide heating and cooling in both hot and cold conditions - certainly capable of maintaining any normal room temperature that we may desire - too cold in the summer, and too hot in the winter if we really want to.
And they do this for considerably lower kWhr or BTU than our boiler, but at a much higher cost due to the cost of electricity vs gas.
As such we use them only when really needed: cooling in the summer (the boiler doesn't do that), and a couple of times when the boiler went wrong!
Just look at any 1980’s era storage heater.
Said to be 100% efficient, because all that electric energy is turned to heat….. just not let out exactly when you want it.
Efficient, but not effective.
texas
United States of America
Other
If other, please explain
interested in the future of humanity
can this produce useful electric energy?
justcurioustwo,
brianmoooore,
