A long while ago I made a roof bolt driver from an old 16mm spade bit, grind the pointy tip off and the cutting edges of the bit until flat! Works a treat and it has a 6mm hex shank so will work in the impact driver or 6mm hand driver!
These are the ones we often get:
They have traditional shallow slot head but the serrated flange nuts. They also offer them in hot-dipped galvanised for outdoor stuff:
(in reality the look a lot duller and rougher than the photo there)
Hex nuts are something of a luxury 😂
CEF. I know that’s a swear word on here but my branch is great.
Local branches stock only std roofing bolts from Olympic Fixings.
Roofing bolts now have 10mm serrated nuts with a PZ2 head now don’t they? Not seen old school ones for years.
Nice, only the cheap rubbish version available locally, with horrible square 0.5mm thick nuts. I usually use mushroom head hex screws and serrated nuts now.
Reactions: DPG and nicebutdim
Best screwdriver for old style flat head roofers is, of course, someone else’s.
RDB85
Trainee
Liverpool
Trainee Electrician
Screwdriver for M6 Roofing Bolts
Electrical Tools and Products
RDB85,
littlespark,
