Discuss Can insulated copper wire handle temporary submersion? in the UK Electrical Forum area at ElectriciansForums.net
As above. You say 'still fresh water' but it's certain to have picked up ionic contamination from the floor, in addition to impurities already in the water (assuming tap water). In 48 hours it could have wicked up a fair bit of cable unless the ends were sealed.
You could, for example, send the end of the cable, including a few metres, to a test laboratory and ask then to assess contamination levels on the copper (e.g. by splitting the cable open)
Maybe discuss the issue with these guys:
As you might guess from the link, my only experience is with contamination of assemblies, not cables, so you would need to find the right expert to give the 'all clear' on your stock (or not). I don't think there are any electrical tests (eg IR) that are relevant here. It is the the presence of internal contamination that will determine the life of the cable, and knowing its history, it would clearly be unethical to sell it as new!
I'm afraid you might find the cost of determining the cables condition is similar to (or exceeds) its scrap value.
I had a 500' spool of insulated copper wire get submerged in a foot of still, fresh water for 48 hours (warehouse flood). Is it waterproof? Usable? Proper way to test it?
You can read the insulation type printed on the wire and it will have if it’s rated for wet locations. I would put it in the sun and let it dry out. It should be fine
Reply to Can insulated copper wire handle temporary submersion? in the UK Electrical Forum area at ElectriciansForums.net
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
I wonder if anyone has some good stories of really easy call-outs made a lot more difficult by the customer's rather fixed views. Here is my...
5K
Hi all, Planning on wiring my neighbour's summer house which will be 15 metres away from the end of the house (20-25 metres total distance from...
7K
Hello i've recently just had a re wire done on a three bed semi house, Ive noticed a few things im not 100 percent on ive spoken to the firm that...
5K
