Say what you see…..
And a few more words
I know, right?I wish there was a facepalm emoji
Can't see them in my end, they're all blank. Like dels mindI know, right?![]()
Poor isn't it... Notice his lack of replies to the comments pointing it out.
Del just removing the main earth from a live TP board.
Dangerous would be the word i'd use!Poor isn't it...
That's because he's incompetent. It's embarrassing for NIC that he's an approved contractor.The thing is, we all probably make occasional mistakes at work, and realise. He's filmed it, edited and uploaded to YouTube and not realised.
I have worked with Approved contractors Way Way worse than Del , in fact they make Del look like a ProDangerous would be the word i'd use!
Ze comes to mind.Why would you remove the Earth when testing a TP board?
I didn't look at the video, i just replied to the “why would anyone disconnect the main earth”.I don't get it, if you disconnect the earth to get a true Ze the you test on the incoming earth cable, not the dis board where he clipped his crock clip.
also do those newer meggers do P-P IPF nowadays, I was waiting for the bang. Day one of the 2391 course and our tutor said never ever test phase to phase whilst doing IPF with a single phase tester if you still want eyebrows. I've always doubled the highest single phase reading.
I looked at the vid a few times, the main TP switch was in off position thats good should of locked it off, now this is the confusing bit Del disconnected the main earth (to the DB) lead away from the MET block because multiple bonds on the block, but still had his clips on it in the DB with all earths still connected picking up other paths. IMO this was not a true Ze. He should of taken the main earth lead out of the MET block coming from the cutout and put his clip on that.I don't get it, if you disconnect the earth to get a true Ze the you test on the incoming earth cable, not the dis board where he clipped his crock clip.
