N
nicebutdim
Managed to read the standard and stand corrected as switches on fused connection units must disconnect both poles.
See, delroy us helping us all learn something!Managed to read the standard and stand corrected as switches on fused connection units must disconnect both poles.
really? ok i thought they all were but i stand corrected
Dustydazzler... this shameless self promotion has to stop ....!
It may have been added in at some point, and if there's no RCD protection in the consumer unit, is a way to provide RCD protection compliance for the new work. Let's hope not though cos del just removed it....Without digging out the regs books, can anyone comment on the RCD socket he removed and replaced with a regular socket? Isn't a socket there full stop against regs since it's directly over a sink?
I just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on thisIt may have been added in at some point, and if there's no RCD protection in the consumer unit, is a way to provide RCD protection compliance for the new work. Let's hope not though cos del just removed it....
I think the 300mm rule was one one of the older Regs that no longer applies anymore. I have seen pop up sockets fitted in brand new kitchens right next to a new sink way closer than 300mmI just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on this
If memory serves me correctly it stated in the electrician's guide to the building regs that sockets should be at least 300mm from he edge of the sink's basinI just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on this
I can't believe i've just sat and watched some guy charge £50 to spend half hour putting on three bits of trunking after debating skirting height for a wall that's gonna be boxed in.. Talk about spinning out a 10 minute job.Absolutely riveting stuff
The money he apparently charges you'd have thought he could afford a laser level, or a least a 4foot spirit.I can't believe i've just sat and watched some guy charge £50 to spend half hour putting on three bits of trunking after debating skirting height for a wall that's gonna be boxed in.. Talk about spinning out a 10 minute job.
Del charges £50.00 +VAT per half hour Monday - Friday (8am-4pm) and then £75.00 +VAT per half hour at all other times. With a minimum of 1 hour.I can't believe i've just sat and watched some guy charge £50 to spend half hour putting on three bits of trunking after debating skirting height for a wall that's gonna be boxed in.. Talk about spinning out a 10 minute job.
Who gives a flying.... no one cares apart from the two people who seem to build their lives around him and this thread.Del charges £50.00 +VAT per half hour Monday - Friday (8am-4pm) and then £75.00 +VAT per half hour at all other times. With a minimum of 1 hour.
Can we please keep things polite on the forum please or I shall close the thread. Err, hold on. No, that's not me. Nurse, nurse!
only if reasonably practicable.By 'shall', do you mean you must or is it just a suggestion?
