- May 12, 2020
- 1
- 0
- 31
- United Kingdom
- Other
- If other, please explain
- Chief marine engineer, responsible for all ships electrical systems
x
I am setting up a series of fish rearing tanks. Each tank will have a 240v centrifuge to collect sediment as I’m drawing water from my lake. The centrifuge has an automatic switch off when the sediment builds up and needs emptied. In the water line is a 240v 30amp UV sterilisation light. If the centrifuge automatically switches off the UV light will overheat and blow the expensive bulb.
What switching relay can I use to switch the UV light off. I can take a live and neutral feed from the centrifuge pumps feed to power the switching relay on to keep the UV power supply open. When the centrifuge automatically switches it pumps off and power feed stops to the relay switch I need it to switch off the UV’s power supply. I can’t put them both on the same supply as the centrifuge supply will still be live even though the pump supply is switch off.
I was looking at the TE Connectivity T92P7A22-240-6-1393211-2
But can’t find a wiring diagram to see if it can be wired to do what I require.
If you could tell me what to use and how to wire it up it would be much appreciated.
