Check the supply voltage is in spec, may need a voltage recorder.
Maybe there could be issues, it's part of a new build estate of small units
TT supply, was it the L - N SPD that burnt or the L-E device?
It looked like the live connection side ( internally) burned against the neutral of the main switch
Kent
Business Name
ABY Electrical Services
Plazma cutter causing SPD failure??
UK
Andy Y,
Andy Y,
