The type of cable would be SWA, the correct means of support for all cables is stated in BS7671.
I am well aware of the difference between wires and cables so patronising members really isn't necessary.
Sorry, I knew this would end like bitter. This is not a fight to prove superiority or knowledge. I have heard many many UK electricians talking about cables, where they meant wires, honestly. Anyway, I contacted Eland and they recommended the right cable. They also agreed that running wires in trunking is a traditional thing and it can cause a lot of issues. I had expected that response.
Again, many thanks for your support and understanding. It was a pleasure!
I very much doubt Eland stated this. Problems are generally encountered through incorrect installation methods or inappropriate systems for a given environment. What cable did they recommend and what did they base this recommendation on.
Properly installed conduit should not damage singles, the point of it is to protect wiring. Work here must be done to BS7671, if you choose to install from another standard this could be a departure, you would then have to demonstrate that's its not less safe than our wiring regulations BS7671
Thank you newfutile, Is installing PVC conduit and PVC trunking in a workshop OK here in the UK? Or would you rather install all in metal? During my apprenticeship we were always told to use metal to metal and plastic to plastic.
Plastic is used most (easier to work with) - but it's down to the installer to decide what is appropriate for the situation. There's a LOT of installs with white plastic conduit into metal accessories.
In my opinion (and fully acknowledging that I'm not aware of the specific details here) PVC (plastic) containment may well be a poor choice for the specific environment, and galvanised (metallic) may well be the superior choice in this instance.
As already said, it's very installation specific. Tgere will be situations where plastic could br a better choice.
Of course, many will insist on installing plastic because they can't manage doing it in galv steel. Or just c.b.a. with the effort.
