F
f1ngerz
Been self employed for years now , but just subbing, had to take the leap to go on my own as subbing dried up. Just starting to go quite and wondered what works best for you guys ? Word of mouth is often said to be best but surly that starts somewhere? Live in Rossendale near manchester, get a millon calls a week but only from companys wanting me to pay (loads) to advetise with someone ive never heard of!
Parish Magazine and locally based recommendation websites great source for small works and doesn't cost the earth but most of mine is through word of mouth and good subbing contacts. Only downside with parish and small town mags most of the work is mind numbing and very small works such as adding 1 socket putting up two light etc but works work I suppose
Streaking..... gets you noticed!:D
Local community mags and newspapers are very good for getting you off the ground.
Run them for a couple of months until your name gets around and then stop them. Probably cost around £50 an edition.
If you find work dropping off again, start them back up.
Utilise sites like Free adds sites also flyers I can send you samples of mine that have worked then once you get established word of mouth follows.
Forgot to add utilise the free webspace you get from your broadband supplier and get yourself a domain name I got 2 years web hosting and domain name from Streamnet for £50
There's several points to consider before dumping your money on any type of advertising.
Successful advertising depends on properly defining what it is you want to achieve from it, for one thing. In turn that, together with other considerations, defines the best method of actually doing the advertising.
Too many times, a budget can be wasted, simply because the person wanting to advertise doesn't stop to consider what the goal really is.
For example - some forms of "advertising" aren't really advertising at all, but work better as "brand awareness" tools - marketing. The two are distinct, but often lumped together, and some forms can fulfill both to some degree.
Really successful advertising will have a well defined plan behind it, with clear goals, and a clear message. Good marketing, on the other hand, will simply shout about the virtues you offer as a prospect.
The difficult thing here is not about where you start, necessarily, but about what you want to achieve, realistically.
Both marketing and advertising have important roles to play, but both offer different outcomes.
So. Let's say that you're a self employed guy, who's subcontracted for years, and is now making the leap into getting work for yourself, on your own efforts.
First question - what work do you want? Specifically?
First Pointer - it is rarely a good idea to write a list of EVERYTHING you can do, cram it onto a flyer, and hope it sticks with people. Most times, especially on limited budgets, it is far better to limit your message to one key service, from which you can leverage other sales.
Second Question - having defined the work you want, figure out where your market for that kind of work is.
Second pointer - you won't find commercial customers reading parish magazines, responding to leaflets, or in all probability, looking in the local free-ads. Similarly, you won't necessarily find domestic customers looking in trade journals, directories, or responding to direct email.
So ---you should by now have an idea of your "winning service", and who is likely to use that. In turn, this gives you some kind of focus as to what form of advertising might work best for you.
Let's say, for the moment, that you want most of all to advertise your availability to complete commercial PIRs.
A suitable way of doing that might be a direct mailing, or yeah, leaflet to local businesses, *because* it is a low value service, easily priced, and easily fulfilled - oh, AND often wanted - coupled to direct email. In this way, you can create advertising which compels your recipient to respond somehow - with a discount voucher, or a special gift of some sort - which needn't cost much at all, and which you've already priced in for. The key thing here is you are trying to convert leaflets into work AND trying to gain a customer list you can resell to, so data capture is important too.
Now, let's say that you want to advertise an offer to commercials to re-wire their premises. This is far harder to advertise, as it is a big sell in most cases, high value, and not often wanted - the difference this time is you want it more than the customer does. In this case, advertising, per se, isn't really going to work at all - because you have no idea who to advertise to, beyond "commercial premises", only 5% of whom may need a re-wire.
There's two points to this - one, advertising that kind of service isn't a great idea, and two, advertising something that people want, and is easy to fulfill is ALWAYS the best way in.
In the case above, what you would turn to is marketing. That is how word would get around that you do that kind of work. You "advertise" or market your availability such that people who actually need that service know where and how to find you.
In any case, marketing plays a part in making sure any advertising is effective. Where, for example can any customer find out more about you, about what you do, and indeed, WHY they should use you - reaffirmation of what you say in your advertising. And the single best way of doing that these days is a good, concise, well designed web site, properly targeted to your intended customer base, and ranked well on Google. We've left the days of Yellow Pages supremacy long behind. The good news is, with a little effort, knowledge, and some trial and error, you can do a website that works really cheaply, and you can make it say exactly what you want.
About word of mouth. It is the single best form of both marketing and advertising there is - but only if done properly.
The key to success in word of mouth advertising (which is really marketing anyway), is in asking for the lead, and following it up. Be proactive. Have a satisfaction form, and ask customers you do have directly on it to recommend someone to you, who they know also needs work. Even to the point of offering them a small discount on their bill for a successful recommendation - everyone loves to get something for (the perception of) nothing.
However, WoM can also be dangerous - the stats are something like for every one satisfied customer you gain, you potentially lose ten. The moral, such as it is, behind that one, is to always deliver what you say you will, when you will, how you will.
In short, keep the promise simple, and easy to deliver. If you say you'll call someone, do it. If you say you'll be somewhere, be there. - This is building up the key ingredients of successful business - reliability, integrity, and good service. Those three things allow word of mouth to work for you like nothing else.
It's hard to go further without knowing exactly what sort of customer you're looking for, or what it is specifically you want to offer them, but hopefully, the above gives something of help to you.
It depend what works for you I spent £90 on 5000 double sided flyers and it did the job but I realise now I could have got more work if I had made it simple. I spent £126 on local mag that covered 5000 households and got 1 job and made £50. I also built a website via my free webspace from my broadband provider and once I got it right I linked it to my free add site then I got a domain name and 2 years hosting for £50. Also tried shop window but no joy and then again this only cost me £2 for 4 weeks so nothing ventured nothing gained the other point is my customer fall into 2 sections old 55+ that want recommendations and young 25+ who want to find at the click of a mouse
And what about the ones in the middle who want to find you at the click of a recommendation, or at the recommendation of a mouse?
It is as you say, nothing ventured and nothing gained - no advertising is ever a total loss, if done at least half way well - it serves as good marketing, and raises awareness a degree or so.
Best advice, as hard won, and said earlier, is to keep it simple, and to go for one "service" at a time, which is most likely out of all you offer to be taken up - something likely to win sales - like PIRs, or "extra sockets fitted" - anything you can offer at a fixed price, do well, and quickly, will win you more customers, and then you keep their details to send more complex offers later on.
