Depends on your budget really, however, Hager, Contactum, Wyles are good.
You may be better off installing a 5+5 dual rcd split load cu and spread the circuits over both side to comply with the latest regs.
Can you please recommend a good 6 way consumer unit for a one bed house.
Have you got 6 ways being used at the moment if so you should really put a consumer unit with some extra spare ways to enable new circuits to be installed in the future without the need for another CU change.
