Discuss Consumer Unit Change in the Australia area at ElectriciansForums.net
Depends on your budget really, however, Hager, Contactum, Wyles are good.
You may be better off installing a 5+5 dual rcd split load cu and spread the circuits over both side to comply with the latest regs.
Can you please recommend a good 6 way consumer unit for a one bed house.
Have you got 6 ways being used at the moment if so you should really put a consumer unit with some extra spare ways to enable new circuits to be installed in the future without the need for another CU change.
Reply to Consumer Unit Change in the Australia area at ElectriciansForums.net
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
