Thanks Des. It's an ex BT van so came with the racking already installed. Got fed up not finding anything in my previous Astra van.
Thanks Mogga, i might get some more pics later if i get time as i need to do a list of tools and stuff for insurance purposes. The Shelf really does make a difference, saves bending over the whole time crawling into the back of a van etc, and also, when the tool bags are out and 'on-site' etc, it gives me a little work table subject to weather to prepare/count bits and pieces prior to going into a job. :)
Because 4 days of snow makes van like this:
Decided to turn this:
Into this:
Honest and funny pictures brs73 and a12spm
Its a relief to see I'm not the only one who throws the gear around :o
In the van beauty competition,it would have to be first prize to brs73
a12spm spoiled his chances with that dreadful clean up and organising of a once proudly owned mess :)
I have a confession while I was using it to cut the wall through I did cut the chase for the new oven supply while I was at it lol
And it has been used to cut 70mm swa before
Very useful for removing Cowboy Clampers wheel clamps too ;)
I used to have a trafic...great van. does anyone else fit inverters to charge their drills etc in their van?I found it a godsend...used to run a flex to the alarm panels for programming systems before the power was on.
I was planning on putting an inverter in mine very shortly to do exactly the same thing. Great idea about running a bit of flex to program things whilst powered down.
KNIPEX,
Guest55,
