Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
The leads are a year old. I'm charging the battery at the moment but it was showing about 1/2 charge I guess when I was testing earlier. If its as simple as a low charge then I'll be delighted.
I had the same problem with mine. Found a loose connection inside connector/probe end of one of the test leads. Re-soldered connection, good as new. No problems since.
