V
So long as your spur cable is 2.5mm2 and you put in isolation as lighthouse says then you should be OK for that section.put in bigger drawing now so hopefully you guys can see it. sorry the other one was so small my mistake.
Change the "flex outlet", on your fridge/freezer for a switched spur outlet, as per above replys.
Think I can see what your hoping to do from your picture.
Looks like your going to connect the appliances via a spur outlet. If so, have a switched spur outlet at worktop level, supplying a single socket below worktop level. This allows your appliance to be disconnected from the supply without having to move the appliances. Also allows you to keep the plug top attached, this will not violate any warrenties from the machines makers.
The appliances were integrated and they went right back to the wall almost. There was no room behind the appliance whatsoever to plug the appliance in. Had to modify things in a hurry.
That's interesting "Rocky". I have seen some on cable left in the floor but dont like that idea due to water ingress. So you chase down from DP switch below work top and then flex and socket hanging down the back od the appliance?That's exactly why I use trailing sockets on flex! Can throw them anywhere they fit, that way.
