K
K-PAT
Further to the recent post about testing fixed wired appliances, I found the replies helpful, but would appreciate if someone would be able to give a definitive answer on one particular point.I am quite confident in disconnecting the wiring from the fused socket and inserting the flex into a Quicktest connector in order to carry out the test sequence.I am also confident in replacing the flex in the fused socket.However...having done this, am I right in thinking that the connection then needs to be checked/tested by a qualified electrician before the appliance can be put back in service? If so, this would tend to put me off doing the test as the client will not want their appliance out of service when I have tested it.
What I'm really trying to do is stay on the right side of any regs, while giving the best possible service to the client.
Is there a minimum level of training that can be undertaken in order to carry out these disconnections/connections, without doing the full electrical courses?
Thanks for reading and for any advice..
K-PAT.
K-PAT.
There's always one, isn't there.
