Guest viewing limit reached
On the back of a thread I started I thought I'd start this since there doesn't seem to be one and I'm sure we all have a right good few that would scare those in the know.
How many supplies does one need!
Cable Raggle Extra
Not so much Shame but old
Any idea of age?
Beautifully terminated garage SWA and a nearby socket.
Well, at least you can see the colours clearly... Lol!
Ooops, just looked again... I take back my previous remark (unless those meter tails are unsheathed, of course).
Sent from my Samsung Galaxy S II via Tapatalk
who cares if they are sheathed or unsheathed, theyre the wrong colours!!! didnt know you could still get green as opposed to green and yellow!
Another job this week.
Client has an outside jacuzzi.. Oooer missus.
The guys that fitted it when straight off the meter with their SWA. Nicely done. But no OCPD for the cable other than main cut out (100amp fuse) until the RCD just before the jacuzzi itself.
loving the silicone instead of a blind grommet or a stuffing gland!!
Are those Gizmo's still around that sent the metre backwards while using the free leccy?? The one's i remember where 2 16mm singles coming out of an epoxy filled plastic IP type box.... Think they just rammed the two tail into the meter cable connections ....very quickly, ...to minimise the splashing and arching that went with it!! ...lol!!!
i remember them about 20 years ago, brings back memories!!!, i curiously got my hands on one and decided to open it up to see how it was made and it was basically a little cheap and nasty down convertor ac transformer wired up in reverse order nothing else.
Glanding. Who needs it?
And finally I think there's an urban myth going around that states if you chisel a big enough hole in the side of the fan housing you don't need a gland or a bush for the cable entry.
Oh, I've got enough pictures like this to post at least ten each day for the next week :) I had a clean-up of my pictures drive the other day so I pulled a few gems for you're perusal and enjoyment.
This 'installation' is exactly as it was. No covers were removed before the photo was taken.
And there's you complaining of people coming over to SA and installing electrics to there houses to meet the likes of BS7671, DIN/VDE, NEC etc etc!! lol!!!
Makes me wonder when these bozo's step back and cast an eye over the fruits of their labours....what the hell goes through their minds?
Here's one more of a commercial lighting installation in a very high end restaurant, also done to the same irreproachable standards and codes.
Lol, we ripped the entire system out and reinstalled from scratch on just about all these jobs. The pictures were taken for inclusion in the quotes to give the customer an idea what they have and why they might want to pay us to replace or repair it.
You'd be surprised, most of the time this kind of kak is above ceilings or in places they don't see it. They're usually blissfully unaware and we get a call after three or four other cowboys have taken money off them and failed to fix the problem.
I've got a photo of a CU in China that'll knock the pants off of anything you've shown so far!! lol!!
I looked at this CU (if you can call it such) ...pulled at a few cables to see where they were going, but after half an hour or so gave up, ...couldn't see how or what was happening or what anything was doing. This was to a small 2 bed apartment... Wanna see it ?? lol!!
Too right!!
OK, here it is.... See if any of you can make out what's going on...lol!!
This DB was installed just 13 to 14 years ago believe it or not lol!! The Meter is quite sophisticated it can be contacted by mobile phone to credit it's account. If only the rest of the installation was up to that same technology ...lol!!!
No idea what the 2 fuses do, the breakers control lights and sockets in the apartment!! not separately, they both control a portion of both the light and sockets. No cooker outlet, they don't use ovens in Sth China, so just normal sockets in the kitchen... all 2 of them!! Voltage is 230V throughout. Oh, and they may look like rewirable fuses but there not, ...they have flat oval cartridge fuses!!
I think you've got to look at these installations in a much deeper and holistic way in order to get the most out of them. As far as this one goes I'm liking it on a poetic level. Immediately before it's uncorked there's an assault on the visual palate. The bottling and labeling is in the ageless trend of minimalism which lulls you in a false sense of security. Then you taste and right off the bat you've got that old meets new thing going on, it's simple yet with a very complex after-taste and not a hint of wood.
I'm guessing this CU is lacking mainstream appeal and won't be to everyones taste but it's got merit and well worth the effort to appreciate it.
Not sure really. But his back leg was in the poorly terminated live terminal and his wee sleekit nose could have brushed the earth strap.
At least the customer found out why he had flies in his flat in the middle of winter.
There's a story behind this photo, it's not the usual moron-installed rats nest. We put in a request to the power authority to have the metering box relocated out of the fire cupboard. They replied saying the enclosure belonged to them as they installed their kit in there first. We requested a site meeting to show them the equipment. The main water castings were manufactured at Mather and Platts in Manchester and had the date cast in the front which corresponded with the hand written maintenance paperwork that was also still in the cupboard. The date was several years before that area of Cape Town was electrified. They conceded that they might be mistaken about it being 'their cupboard' and moved their equipment without further ado or costs.
North Lanarkshire
Hall of Shame Photos
Australia
Wully,
Barry Rathbone,
