On the back of a thread I started I thought I'd start this since there doesn't seem to be one and I'm sure we all have a right good few that would scare those in the know.
How many supplies does one need!
Cable Raggle Extra
Not so much Shame but old
Any idea of age?
OK, here it is.... See if any of you can make out what's going on...lol!!
This DB was installed just 13 to 14 years ago believe it or not lol!! The Meter is quite sophisticated it can be contacted by mobile phone to credit it's account. If only the rest of the installation was up to that same technology ...lol!!!
so they dont do IP ratings over there in china eng?..lol......
Okay, this is one of my personal favorites. The story the customer told went like this. This board had been problematic for a while, many tripping faults and a small fire later an electrician had told them it needed stripping and rewiring completely. The customer said okay and this was the board after the rewire.
When they'd finished the work both RCD's couldn't be reset without immediately tripping again. I really felt bad for the guy who rewired it (yeah, right), he obviously got confused because he'd used what was supposed to be the earth bar as one of the RCD neutral bars. In an attempt to bypass the problems this caused he'd removed the main earth from the terminal on the enclosure and used choc blocks to run the earth all over the panel so the circuits could connect to it without contacting the chassis.
This was one of the few appalling jobs where justice prevailed and the customer had seen the debacle before he wrote the cheque so the moron didn't get paid thankfully.
had one the other day.....1.5mm T&E spurred off a 2 gang socket....feeding a 2 gang socket......told em they could either have a 1 gang or a no gang..lol....we were changing old to new switches/outlets by the way.....
Just this afternoon, in my wholesaler, a gentleman was buying 25 meters of flex to run a cable through a hosepipe down his garden.
Lord only knows what he was going to put on the end of it!
Maybe i take my hat off to him if he manages to thread 25m of flex through a flexible hose.... a task that aint gonna be as easy as he thinks :)
Camera installer drilled through this cable and 'fixed' it. "It's a permanently fixed cable to the homeowner" oh good no worries says the homeowner.
Bearing in mind this is a barn gutout and rebuild and hadn't even seen power at this point 3 weeks ago!!!
Luckily for me it was shown as I walked in a week later to finish off wiring, fuming wasn't the word.Was promptly replaced in 20min.
God knows what would have happened if the plasterers had covered it......Chock block.jpgInside chock block.jpg
North Lanarkshire
Hall of Shame Photos
Australia
Wully,
Barry Rathbone,
