Stoutlad :-) - where are you geographically, tell us quick or you could end up spending thousands!!!!
I am going for a low reading in meg ohms if you IR this, something like where the regs state below 2megohms then investigate.....this could be the case
Well he hasn't phoned back, thought he might have phoned last night or this morning just to let me know he got my message and maybe say when he could have a look so I have went and got a new MCB @ £16 odds and tried it and it appears to be working. Had it running for 7 minutes without it tripping. Hopefully that's what the problem was but I'd still like it checked out to make sure there's nothing else wrong
I'm wondering if it will be safe to use in the meantime until he comes, he often does small jobs on a Friday
Just goes to prove, the simple things are generally the best things to check/change first. Seems the OP has replaced/changed just about everything on this installation except the cable, ..Shame the MCB was the last thing rather than the first...lol!!! Expensive learning curve that one, but one he won't forget in a hurry!! lol!!
Yes :icon9: . Hopefully the old shower was what caused the problem with the MCB, can the old one (shower) be tested without being connected up? About 4 years is all we ever get out of those type of showers usually, ofen not even that. In years gone by we never had a MCB, it was just a fuse but the shower used to blow too after about 3 years
Still not been to check this out by the way, what was that about electricians coming when they say and plumbers not? :)
Where are you based? Someone on here will be out to you within the hour. You've either got a short on the cable run or a faulty mcb. Won't take long to find
Triton do have a good customer service line and might well be worth a call and explain what its doing.
don't think scottish circuits leak to earth, there too tight :)
watch out, mogga's about.LOL.
