T
tuckermot
Hi all
I am going to start rewiring a 1930,s house in 2 weeks time ,the upstairs dividing walls in the bedrooms are lathe and plaster .I am going to be pulling the upstairs lighting feed to all the points and dropping the switch drops before chasing as going to leave the house running as its ocupied.I have not come against lathe and plaster walls before i can sort back boxes out using dry line back boxes but not sure if i can cut out back box and pull the cable from the loft through the middle of the lathe and plaster with draw rod and in to the dry line back box how do you do it ??
Richard
Richard
