W
w crane
Simple question.ah
is it possible to puchase a
[h=1]Double-Pole Double-Throw Switch.[/h]which looks like a normal wall switch used to operate lights.
any help cheers
might be able to get one in the grid switch format.
crabtree do a 20 amp double pole that looks like a normal switch
We used to use the Gewiss Playbus range, which contains a reversing switch amongst just about every other kind of grid mounting accessory you can imagine. I think we got them from Electric Centre. They're Italian so they look nice but aren't exactly what you'd call 'robust'.
Alternatively you could use an actual ordinary light switch with a DPDT contactor sited remotely.
i will try and get in touch with Electric Centre, thank you very much.
and to every one that has helped thankyou.:lightbulb:
Could I ask why you need a DP DT switch?
designing circuit for taxi office :outside movement detector floods / sirien . min number of switches , no relays . got it down to one DPDT and a single way sw.This give me several option to put circuit into.
Then was told design would not work because the type of wall switch DPDT i needed (to match existing sw's) did not exist.
Also your not alowed to have a sirien hooked up to a external sensor.
Hence snookered both ways. ahhhhh:nopity:
But i would likje to prove existance of switch if possible .
w crane,
w crane,
