OMG. a cat with a reciprocating paw. whatever next?
TC, your not the first and wont be the last.
OK the blades a bit screwed up now.
It's just another of your lives gone...............
I did it myself earlier today! Managed to nick two cables and cut right through a third....out came the crimpers.....
Just to let you know that i used my Bosch multi tool vibrating cutter thing today (as you can see i don't know the proper name for it!).
Anyway, i was using it to cut a box out for a lath and plaster wall. It cut it really well until i heard a bang, a scream from the lady downstairs and i realised i had cut through the 3 core from the landing 2 way!
I haven't changed the board yet so still rewireable fuse, made quite a bang.
Be rest assured guys you don't get a shock but the blade has a nick out of it and is a bit black!
never trust a cat...
It's called a GOP multitool, both my vans keep a 10.8V lith ion on board (mine was part of a free monster kit from Eddies when I spent over £4K with them last summer) Great tools, like a more accurate electric chisel! Great for cutting out dado/picture rails/skirting board for trunking runs or really neat cuts in floorboards. Won't use mine in lathe & plaster again tho. Took out all the teeth on a blade in about 1/2 second. (grit in plaster)
